Skip to main content
Vectorworks University
  • Courses
  • Certifications
  • Dashboard
  • More
Sign In
  1. Home
  2. Courses
  3. Vectorworks, Inc - Global
  4. Certifications
  5. Landmark Certification
  6. Landmark 2024 Certificaiton
Course Languages
Course Language
Course language
(2024) Skill
PLANT TOOL - ROOT BALL AND EXCAVATION
Intermediate
4m
Start
When the specification of your plants has been confirmed, you can edit the plant styles in your project and set up the root ball and excavation pit settings based on the sizes that will be installed onsite. These can be shown in both 2D and 3D, having root ball and excavation pit data helps aid designing and planning around your plants and to use in a BIM workflow for clash detection.
Landscapes
Landscapes
4m
Intermediate
Learning Objectives
  1. Edit the plant style root ball settings
  2. Edit the plant style excavation settings
  3. View the root ball and excavation in 2D and 3D.
(2024) Skill
SITE MODEL SNAPSHOT
Intermediate
3m
SITE MODEL SNAPSHOT
Start
The Site Model Snapshot is a key component of Site Model analysis in Vectorworks. In this video, you will explore the Site Model Snapshot feature and it’s uses.
Landscapes
Landscapes
3m
Intermediate
Learning Objectives
  1. Create a Site Model Snapshot
  2. Adjust the settings of a Site Model Snapshot
  3. Explore the benefits of freezing a Site Model Snapshot
Overview
FENCE TOOL – DRAWING A FENCE
Intermediate
14m
Start
The fence tool enables you to incorporate detailed fence objects into your design. When using the fence tool, you will have the ability to draw fences using fence styles from the Vectorworks libraries or you can create your own fence styles and save them to your library of choice for future use. In this video we look at the drawing modes of the tool along with using the reshape tool to make any amendments to the fence after it is drawn.
Landscapes
Landscapes
14m
Intermediate
Learning Objectives
  1. Draw a Fence.
  2. Draw a Raked fence.
  3. Draw a Stepped fence.
  4. Reshape and amend the fence.
Learning Path
VECTORWORKS 2021-2023 CORE ASSOCIATE CERTIFICATION
16h
Start
ⓘ  Note: There is an updated version of the Vectorworks Core Certification. To access the latest version, please click here.
Master the key skills required to be successful in Vectorworks by earning your Vectorworks Core Associate Certification. This learning path contains over 170 courses and exercises that will equip you with the essential knowledge to operate Vectorworks with confidence. The Vectorworks Core Associate Certification learning path and exam are available free for a limited time.
To earn your certification, you must successfully pass the certification exam, with a score of 80% or higher. There are no restrictions on how many times you can retake the exam. If you do not pass on your first attempt, we recommend reviewing the certification courses and trying again. By passing the Vectorworks Core Certification exam and receiving this certification you will demonstrate to employers and clients that you are competent in core Vectorworks tools, commands, and workflows.
We highly recommend going through all of the courses in this learning path before taking the exam. However, we know there are many experienced Vectorworks users out there. If you feel you have already mastered the subjects covered in this learning path, you can skip directly to the exam.
Your certification is valid for 3 years after successfully passing the exam. Once you pass the exam, you will be able to download and display your personal Vectorworks Core Associate certificate and seal. You will be notified 6 months before your certification expires and with updates for continuing your education.
Welcome to the Vectorworks Certification Program!
All Industries
16h
Vectorworks Global
Learning Path
WINDOOR TUTORIAL
Beginner
4h
WINDOOR TUTORIAL
Start
Buildings
4h
Beginner
Vectorworks AU
Learning Path
CABLE TOOLS SUITE
Beginner
2h 20m
CABLE TOOLS SUITE
Start
Video
Entertainment
2h 20m
Beginner
Vectorworks Global
Learning Path
Beginner
8h
Start
All Industries
8h
Beginner
Vectorworks Global
Learning Path
Beginner
8h
Start
Buildings
8h
Beginner
Vectorworks Global
Learning Path
Beginner
8h
Start
Landscapes
8h
Beginner
Vectorworks Global
Learning Path
Beginner
8h
Start
Entertainment
8h
Beginner
Vectorworks Global
Learning Path
Beginner
8h
Start
All Industries
8h
Beginner
Vectorworks Global
Learning Path
ONBOARDING - EDUCATIONAL
Beginner
8h
Start
All Industries
8h
Beginner
Vectorworks Global
Expand all
(2024) Skill
Overview
Archive-Delete Landmark Skill
LANDMARK CERTIFICATION SECTION 1 GUIDE & COURSE FILES
SURVEY INPUT COMMAND - OVERVIEW
SURVEY INPUT COMMAND - IMPORT DWG
SURVEY INPUT COMMAND - GRID ENTRY METHOD
SURVEY INPUT COMMAND - 2D POLYS TO 3D SOURCE DATA
SURVEY INPUT COMMAND - 3D POLYS TO 3D LOCI
SURVEY INPUT COMMAND - IMPORT SURVEY FILE
CREATE SITE MODEL COMMAND - OVERVIEW
CREATE SITE MODEL COMMAND - CREATE SITE MODEL FROM BOUNDARY
CREATE SITE MODEL COMMAND - VALIDATE 3D DATA
CREATE SITE MODEL COMMAND - CREATE SITE MODEL FROM SOURCE DATA
PROPERTY LINE TOOL - OVERVIEW
PROPERTY LINE TOOL - PREFERENCES
PROPERTY LINE TOOL - POLYLINE MODE
PROPERTY LINE TOOL - BEARING AND DISTANCE MODE
MASSING MODEL - OVERVIEW
MASSING MODEL - CREATING A MASSING MODEL
SEND TO SURFACE COMMAND - OVERVIEW
SEND TO SURFACE COMMAND - SEND OBJECTS TO THE SITE MODEL SURFACE
EXISTING TREE TOOL - OVERVIEW
View more
© 2025 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
Vectorworks, Inc
Privacy | Contact Us
Powered by Moodle Workplace
