This video will look at the Arc Length Dimension tool.
In this Quiz you will be tested on your understanding and knowledge of basic interactions, 2D Geometry, Editing and Duplicating geometry.
In this Quiz you will be tested on your knowledge of Resources, Symbols, and Graphics.
In this quiz you will be tested on your Knowledge of Sheet Layers, Viewports, Annotations and more.
This quiz is to check your understanding and knowledge you have gained on Design Layers and Classes.
Is this quiz we will test your understanding of the User Interface, Navigating Vectorworks and also the preferences and settings you can set.
In this video, we will explore how to use the Angular Dimension tool to dimension drawings.
This video will demonstrate how to use the Constrained Linear Dimension tool to dimension drawings.
This course will look at the Unconstrained Linear Dimension tool to dimension drawings.
In this video we will guide you through using the Onscreen View Control cube. Taking you through the different options and settings to help with working in a 3D environment.
Put your Vectorworks knowledge to the test and achieve your Vectorworks Core Associate Certification. The Core Certification exam tests knowledge of the basic concepts and skills needed to be proficient in Vectorworks design software's core functionality. The topics covered in this exam are available through on-demand video courses on the Vectorworks University. Learners should be comfortable with the Vectorworks interface, understand clicking behavior, and have a general knowledge of tools, menu commands, and understand document organization before attempting this exam. By successfully completing this exam with a score of 80 or higher, you will earn the Vectorworks Core Associate Certification.
