New to Vectorworks? Check out these quick tips.
Combine the strength of Vectorworks with the speed of AI image generation powered by Stable Diffusion. Directly available within the Vectorworks interface, this experimental feature uses Vectorworks Cloud Services for a zero-install, uninterrupted workflow to quickly ideate illustrative concepts or create refined images using your Vectorworks models at any stage of design.
Explore your designs with Vectorworks Odyssey, a virtual reality viewer app created for Meta Quest 2 headsets and beyond. Experience models in immersive VR with bird's-eye view and walkthrough modes. Gain better context for quick and thorough feedback, including cycling through design options with access to design layer visibilities.
In this course, we'll learn how to connect an external database to the records in our drawing. Using SQLite as a database source, we'll quickly fill our records with data without having to manually retype anything.
Join us to see how four Vectorworks 3D modeling experts create their projects in Vectorworks Fundamentals. They’ll showcase some of the many versatile tools and workflows of the software to design and showcase their projects.
Come see the power
of solid, subdivision, and NURBS modeling, surface arrays, rendering and lighting techniques, and much more.
Enhance your workflow with a better way to create custom graphic legends. It’s now easier to align, scale, and alter the dimension of images as well as customize dynamic text. You’ll also be able to preview changes in sorting and class visibility.
Experience more freedom when transforming your models. The new 3D Dragger will always appear in front of the selected objects for easy access, and contextual handles for translation, rotation, and scale provide comprehensive and intuitive ways to transform selected objects without disruptions. Additional modes like snap-free, planar, and auxiliary rotation options give you the control you need to make your modeling process smoother.
Experience better connectivity to external project data stored in Excel files. With the new Microsoft Excel referencing capabilities, you'll be able to create a new reference in Vectorworks, meaning you can opt for automatic updates to referenced files. Additionally, you can make changes in Vectorworks and push the data back to Excel.
With new Viewport Styles in Vectorworks 2024, you'll be able to save custom viewport settings as styles, making them easily transferrable between viewports and project files. You'll be able to cut out the tedium of replicating your viewport settings and avoid errors. Create custom styles that let you change scale
or class and layer visibility so you can change from client-facing drawings to
more detailed construction plans quickly and easily. Quickly generate presentations from your section
viewports by changing class visibilities, cut plane attributes, and
visibilities at the cut plane and beyond. Easily interchange different rendering modes,
foreground and background rendering settings, and image effects. You can also
save your data visualization settings as Viewport Styles for faster
application.
Create higher levels of realism earlier in your design process with improvements to Shaded rendering. Take advantage of unlimited shadow casting in real-time processing to assess your designs more confidently on the fly and quickly determine lighting, camera, and material setup so you can create better visuals more quickly. The shaded options dialog now includes direct
access to lighting controls, like ambient and environmental lighting, and
Renderworks background controls. Access all new camera settings that allow you to
define depth of field, exposure, and the ability to add bloom for camera-like
effects on your shaded render views.
The updated and modernized user interface makes working in Vectorworks more efficient and easier to customize. The reorganized View and Mode bars bring a wide range of tools to the forefront, so you can decide how to organize and have everything you need right where you need it. And dark mode is now available on both Windows and Mac.
